Does anyone know how difficult it will be to remove the roof lining, re-attach the rear window washer pipe, and then refit the roof lining? Has anyone done this before?
Does anyone know whereabouts the rear washer pipe goes in a nova?
If I decide not to re-attach the pipe, is there a plug/bung that fits in the rear wiper so it can be removed?
Cheers :beer:
Pull the pipe from the pump on the tank under the bonnet.
The pipe has probably split & perished with age. It'll usually dumps all the screenwash down the rear arches & out into the boot floor.
think the pipe runs up over the pillars accross the roof. Try peeling the rooflining down from under the rubber tailgate seal & see if you can see it. The roof lining is clipped up into place.
im refitting a wash wipe to mine, and im gonna run it down the Cpillar and along the bottom through the rear door cards and into the kickplate, bugger me if im gonna be taking the windows out an **** to get a pipe back inplace :p
