Hi,
i need a Vauxhall x14xe race engine for my single seater race car, the car should weigh about 450kg wet with driver. The engine Must comply with the following rules,
essentially just for this one race season I’m looking to get as much HP/torque out of this engine as possible. As long as it can manage the 8 hrs it needs before rebuild it doesn’t matter.
So if anyone out there has some advice on performance/reliability/any tricks iv missed I would greatly appreciate it I honestly would. The engine is being build by a very well known race engine builder but he doesn’t usually do these engines this extreme so he suggested asking you guys.
thanks in advance
Tom
- No Turbo/supercharging or nitrous
- It must be therefore normally aspirated with Weber’s/dellortos/bike carb conversion/throttle bodies
- crank, rods, pistons are free in terms of design/material/source ie different engines. They can also be lightened or modified as needed.
- Maximum overbore is + 40
- cams free
- valve gear is free
- Head cannot be ported but can be fitted with larger valves and the CR is also free.
- fuel is free and I’m planning to run on 115 octane 20% oxygenated race fuel. Races are 20 mins in length. The engine must last 8 hrs before total strip and rebuild.
- Engine must be wet sump
- I will be using an MBE programmable ignition.
- Enem have offered the following cams stating although designed for the C20 they have had some excellent results with full race x14 and x16
- Planning on a CR of 13:1
- Custom JE slipper pistons ? 1/3 shorter than stock
- Pauter con rods ? 1/3 longer than stock
- Lightened and balanced crank
- Ultralite TTV flywheel
thanks in advance
Tom
