1 - 1 of 1 Posts
Automatic Torque Biasing Differentials
The unique design of the QUAIFE patented A.T.B. differential provides smooth constant traction for racing or slippery road conditions.
Suitable as a replacement for any rear or four wheel drive application, these differentials have the added benefit of no adverse effect on the steering of a front wheel drive vehicle. The A.T.B. differential is widely used from Formula 1 to emergency vehicles and public utilities where all weather mobility is essential.
Available to suit a very wide range of vehicles, including Ford, BMW, Mercedes, Land Rover/Range Rover and light commercials. The differential progressively locks as torque increases; there are no plates or clutches to wear out as more conventional limited-slip designs. Is particularly effective in combating the effects of FWD torque steer.
The Ultimate Differential
The QUAIFE Automatic Torque Biasing Differential enables your car to accelerate quicker and corner faster.
How? By getting the power to the ground!
The QUAIFE Differential powers both drive wheels under nearly all conditions, instead of just one.
With an ordinary open differential, standard on most cars, a lot of precious power is wasted during wheel spin under acceleration. This happens because the open differential shifts power to the wheel with less grip, along the path of least resistance.
The QUAIFE, however, does just the opposite. It senses which wheel has better grip, and biases the power to that wheel. It does this smoothly and constantly, and without ever completely removing power from the other wheel.
In cornering, while accelerating out of a turn, the QUAIFE biases greater power to the outside wheel, reducing inside-wheel spin. This allows the driver to begin accelerating earlier, exiting the corner at a higher speed.
The QUAIFE also controls loss of traction when the drive wheels are on slippery surfaces such as ice and snow or mud, providing the appropriate biased traction needed to overcome these adverse conditions. The QUAIFE Differential provides constant and infinitely variable drive. Power is transferred automatically without the use of normal friction pads or plates seen in other limited-slip designs.
The QUAIFE'S unique design offers maximum traction, improves handling and steering, and puts the power where it is needed most. A definite advantage whether on the track or on the street.
The QUAIFE is extremely strong and durable and since the Quaife is gear operated, it has no plates or clutches that can wear out and need costly replacement.
The QUAIFE is great for street driving or racing. Racers don't have to put up with locking mechanisms or spools that tear the steering wheel out of their hands when cornering. Because it behaves like an open differential during ordinary driving, street drivers will have trouble telling it's there until pushing the cars limits.
The QUAIFE has been proven in everything from SCCA Rally to Formula 1. It provides autocrossers with such an advantage, it has become "required" equipment for a winning effort.
For more information on Quafie product see their web site at www.quaife.co.uk
1 - 1 of 1 Posts
