1 - 9 of 9 Posts
I took my inlet pipes off tonight and found them full of oil. The oil is being blown through the CAC and turbo and back into the engine. Also noticed injector 4 has a nice covering!
The oil has come from the breather pipe on the rocker cover. Looking it up it seems to suggest crankcase pressure. What can cause this? .. and as a result what damage could it have caused?
Its on a Diesel Astra by the way .. DT engine.
Discussion Starter · #2 ·
I've just removed the oil cap whilst the engine is running and there is ALOT of air coming out of the engine..
What does this mean?
Worn rings cause pressurisation of the sump
With engine running pull out the dipstick, if lots of smoke comes blowing out - not a good sign :(
Theres no smoke at all??
Could it also be the head gasket?
Never done it before but considering stripping it down to have a look at the gasket and pistons.. will it be easy to identify worn rings?
No I haven't done a compression test.. haven't got a tester.
Sorry for my ignorance but what will this show me?
Discussion Starter · #8 ·
The air is being blown out of the rocker cover. "the oil filler cap"
How do worn piston rings push air up there?
Discussion Starter · #9 ·
Just been out and checked the crankshaft pressure again.
There is a small amount of air coming out of the dipstick but a trivial amount I would associate with worn rings.
But the air flow out of the oil cap on the rocker cover could double as a mobile hair dryer!!
1 - 9 of 9 Posts
