1 - 15 of 15 Posts
I think i might have a possible head gasket problem. I have noticed what looks like oil in the header tank in my corsa. It looks like thin lines of oil floating on the top of the water. I have flushed the cooling system but it is still there. I have done a compression test and all four cylinders are fine. I have checked the oil cap and the dipstick and no water has got in to the oil. Wondering if i could have a porous head or a damaged head gasket that has not yet affected the compression. Does anybody have any ideas?
change it just to be sure. i had a cav with a 2l 16v gt oil in the water but nt in the oil an it split the head lol nt good. just change it to be sure.
there is hardly any oil at all. There is probably only a drop or two of oil in the header tank. It might have dropped in, but it could be something worse.
all up to you then mate better safe then sorry i say. least you will no that it has a new head gasket and you dont have to worry about it...
u always face a head when its been taken off
even if its just been put on, torqued up and not even driven
the metal in a headgasket is enough to leave a mark in the alloy leaving it not 100% true when u take it off..
even if they only take off 2-3 thou which is usually what they do
Whilst the head is off do the porous mod. A lad on here does it for £40. Its piece of mind even if it hasn't gone (sounds like it has though)
I used to have a diagram, can't find it any more, but it showed the differences between the GM casting and the coscast casting. Some say its also a different alloy but couldn't say for sure. As far as I am aware, the 'roof' of the water gallery should have been a uniform thinckness, or at least symetrical to the water gallery to the left (B's in the picture on the causes page) - as you can see from the picture on that site, its not, and at its thinest it can crack. Its a reasonably easy fix though!
1 - 15 of 15 Posts
