1 - 7 of 7 Posts
ive got a corsa b sport and when i start it up from cold there is a really loud ratley noise, and seems to go when it gets warm, i think its coming from under the cover where the cam pulleys are and its getting worse can any 1 tell me wot it is or has anyone had this prob befour thanx
make sure its not just an exhaust heat shield, if not maybe check the timing belt cover is on right. or in worse case scenario could be a knackered timing belt pully, when was the last time the timing belt was changed and was it just a belt or kit?
ive checked everthing to see if anything is loose carnt find it, i know its not the heat shield cuz its tight its had a new belt 6 months ago when i brought it from a garage, i think it was just a belt not to sure.
you get a timing belt, and new pulleys, would think around £60ish, im not 100% sure although i just got a kit for my c20let and that was about roughly that price
1 - 7 of 7 Posts
