21 - 40 of 44 Posts
Hi guys i got
10
1
3
Can someone disipher that for me?
130?
THANKS Alan did pedal test and got 0500 witch is speed sensor malfunction!
Any more advice you can give me on that problem?
Just an addition to this....
I pedal tested a Zaf 04 plate diesel the other month, standard pedal test didn't work. However, ignition to 2 (dash lights up) then pressing the pedals worked. However, it wasn't a flash code, the numbers were displayed on the odometer.
Just reading the other posts people have said they had problems or it didnt work for them. I didnt realise it was for newer engines. I did the clip test on my corsa and it worked fine. I just thought it would work on all vauxhall engines.
Paul. Ive noticed you have helped a lot of people on here :) ive posted a thread regarding my car. Is there any chance you could have a look at it to see if you have any ideas? Thanks
code 42A52
Hi all,
I did pedal test on 2008 twin top 1.9cdti and got code 42A52,which I`m told is exhaust temperature sensor. Can anyone tell me where this sensor is please. Thanks for any help
21 - 40 of 44 Posts
