16vastra - would expect to do a real 125 on a recently rebuilt engine, which given the variances on speedo above 100 should get me to an indicated 140. As important was the painful lack of acceleration above 110 (guesstimate a real 100).
Leads- newish Magnecor , new ngk plugs, new oil filter & 15/40 oil. Fuel filter about 5000 miles old. Injectors ultrasonically cleaned. Will run a bottle of STP cleaner through then change fuel filter.
Driver & passenger weight was circa 170kg, fuel about 10 litres, wouldn't have thought that would matter too much regards top speed.
Will record max rpm reached to provide a truer estimate of real speed, rather than the indicated speed which I guestimate is at least 10% over at that speed
