1 - 11 of 11 Posts
its only small, anything to worry about?
C14SE engine, the bit where the engine number is stamped has a small puddle of oil on it, was cleaned off but has re appeared.
Do i need to worry about it?
Another thing to note is the dipstick reads too much oil in the engine.
Looks like its coming from the head gasket tbh its only a tiny leak, do i need to do anything about it or can i leave it for a bit?
also the dipstick shows the oil way above max, but i have been told if theres too much oil in it, it will just burn off and smoke a lot, is that true?
1 - 11 of 11 Posts
