I have chipped my LET recently and im boosting to about 14psi. This is fine but the only problem is that after going through all the gears boosting fine on the run down the engine light comes on and stays on. The code is 13.
Not sure what to do?? Could it be my bleed valve causing this or could my amal valve broken.
I have my bleed valve on there as it doesn't boost properly without it.
Minty
First of all get rid off the bleed valve and set the boost correctly via the actuator. What chip is it? Have you adjusted the fuel pressure at all?
ya will have to but its just a super chip and no going to get a regulator soon so might sort it out
