ive just finished my c20xe corsa and about to start a conversion on my mates e reg nova sr. it is imaculate so no probs with rot. the only issue i am slightly concerned about is the wiring is this fairly straight forward or not? it was very easy on the corsa but presumably the sr doesnt have a ecu?
Wiring part's easy. Thick red off XE loom with ring connector straight to battery. Black ignition live goes to black that used to plug into the SR coil. You'll have to add a wire to the loom for the fuel pump. Run this from the thick red/blue on XE loom through a 20A fuse to the pump. Run an earth from the pump- to chassis. Green goes to green behind the clocks (or green by the coil) for the rev counter, brown/blue ECU light wire - wire this to the choke light wire (brown/yellow behind clocks) seeing as the SR didn't have an ECU light.
