My Nova GTE engine managment light keeps comming on when you accleate and also when you have run the car, stopped and then go to start it again it starts but stalls straight away. The ecu has been read and it is bring up codes 36(Ron coding Circut) and 42 (no spark timing signal) the engine code is E16SE and the system is the Bosch L3.1 Jetronic. I have changed the ron plug and checked the connections and it still keeps happening I have also fitted new leads, checked the distrubutor and connections are clean I have also changed the coil amp this doesnt seem to have cured the problem. Can anyone help?
