sounds like linkage
you usually associate noise with gearboxes ie whining
the linkage on novas is pretty flimsy, I already got linkage from selector to the box gathering dust in my garage waiting for my existing stuff to fall apart
your gear selector will probably fall through the floor sooon as well
Try this......had to do this on my Cav F18 box
Re set the linkeage...set in neutral, on the top of the gearchange housing on the box there should be a small plastic plug... if you remove this then insert a 4.5 mm drill in the hole that is there and into the gearchange.Release the clamp on the gearchange tube. Un clip the gearlever cover and push the gearstick to the left and insert a 4.5 mm drill into the two holes there (earlier models need someone to hold it in line with an arrow.Tighten the clamp and all gears should be achieved...don't forget to remove drills!!
It is recommended to get a new plastic plug, but you should be ok to re use it
