you can install turbocompressor in two types too. You can put compressor to aspirate air, and pressurize to send to inlet TB/Carb(most common), or you can put the compressor for aspirate the mixture from carb/tb and send to TB/Carb. The most advantage in second option, is only for carbs engines, for security, because in first option, the carb when pressurized, can crash the carbbody(that only made for work in vacuum, and not positive pressure), and in second option, it will continuos work in vacuum, and only the manifold will work pressurized.
Cheers!
