1 - 9 of 9 Posts
CoRsa squeaking NOise coming from wheel!!! please help
HI
I have realised on my car that when i go over speed bumps or slow down slightly there is this squeaking noise. The noise is coming from the drivers side so ( nearside?) wheel i thought it might be the break pads ? or suspension spring?
I was wondering whether any 1 could point me in the right direction as to what it is ??
Thanks ALL
Note: My car is a 99 corsa b (old type) 1.2 thanks
Does it happen when you brake?
Is it a proper squeeeeeeeeeeeak or a quiet whoooooom-whoooooooom?
Alternatively, check your pads for a metal clip (the one that holds them in place) to make sure it's not rubbing against the disc when you squeeze the brakes on. Pads below 50% sometimes get this squeaking sound.
1 - 9 of 9 Posts
