Hi, like the title says im getting a Fuel trim error code P0170 coming up in my 2004 Astra 1.6 Twinport (Z16XEP). Iv had it on and off for the last few months and its starting to get annoying now!
Came on whilst doing a monster trip up the M6 to the Lake District from Oxford, when i reset it with a reader it went away for a couple of weeks then came on again. Now if i reset it, it comes on again within a day or two.
Symptoms seem to be slight hesitation and occassionally when you get up to cruising speed then lift off the rpms rise/fall like a bit of a hiccup. It also idles a bit rough when hot, but generally is no different to how it always was.
I have not noticed any difference in fuel economy and still get around 430miles out of a tank.
Iv tested the MAF sensor resistance and it seems OK, so maybe an O2 sensor to blame? Thing is i dont want to be shelling out for expensive sensors just to find the fault is still there.
Any help would be much appreciated!
