hello every body
i have c20xe on ascona b 77
the problem start after the dirty fuel go inside the fuel filter and coming from other side ( not original filter) and the dirty fuel with oil and rust maybe going inside the fuel pump ... so thats cus i notice the power jumping all time .and in the same time the car start from first try even after 10 days of stop. so i change the fuel filer and clean the injectors and everything ..and still same .. so after i clean the idle valve and change the spark plugs the car is 90% is ok ... but now when i press and go .. its ok but after 4000 rpm i feel the power coming like waves not full of power .. i feel like i pull the hand brake during push and drive ..
do you think guys the fuel pump have a damage and not work 100% ??
or the afm ??
or what 😭 this photo what i found inside the fuel filter from both side
or the afm ??
