hey Vauxy12,
This is what I have got for u....
Mk. IV "Maximus Shield"
Basically the apex of Force Shield during the Incomparable Campaign and Sin Times. As a matter of fact proposed to supplant past Imprints, Mk. IV was strategically adaptable, more force productive, covered a ton of the recently uncovered force links and reinforced up the ones it didn't cover. Most future Imprints will be in reverse viable with this imprint. Exceptionally adjusted, better autosenses, better everything truly. Fundamentally as great as the later Mk. VII and VIII, ostensibly better in certain regards
Mk. V "Sin Protective layer"
Otherwise known as "MacGyver Shield" This is the thing that happens when a galactic scale common conflict among diving beings and their posthuman children fucks up your assembling and coordinations incredibly. Less a standard imprint but rather more the cobbled together, ad libbed mix of other different checks and extra pieces, then, at that point just really famous innovation here are the Atomic Holding Studs that permit one to build up the plates with fundamentally less material. Vital when for all intents and purposes all force shield parts are at a higher cost than normal. Generally disposed of by the Supporters after the Sin, however numerous Tricksters actually wear accepted Imprint V basically on the grounds that they're actually rummaging pieces 10,000 years after the fact.
much obliged.
Does all the front body panels and lights from a mk5 astra fit onto a mk4
No, there are a fair few differences. Could you just a buy a mk 5 instead? Most of them are now the same sort of price (if not cheaper) that the mk 4 anyway.
