I’ve been using the car regular no problems at all. Came to start it one morning and nothing is happening. A couple of month ago I had the same problem so I renewed all of my earths, worked a treat. Checked the earths anyway, no problems. Dash is lighting up ignition wiring is fine. A turn of the key and nothing is there. All fuses renewed.
Starter solenoid issue? Test if you have power going to it when someone turns the key? or if not maybe it's as above, an aftermarket immobiliser issue maybe?
It’s the earth that goes to the back or the block. One of the coolant pipes has split, I changed the pipe but didn’t realise it was leaking directly onto the earth it’s scruffy. The car has no immobiliser so I’m hoping it’s this
