1 - 1 of 1 Posts
Hi guys ive logged into this forum after probably close to a decade hoping someone can help me after months and months of no luck with this car of mine, any help will be appreciated.
Ive got a mk2 cavalier F reg with a c20ne engine fitted
Ive had this car for 5 years and in those 5 years its always had starting problems, very very rarely it will start and when started it runs fine with no problems what so ever.
Ive got 2 Bar fuel pressure while cranking, injectors are opening for fuel, spark plugs are getting wet.
I have spark at all 4 leads, spark is good (tested with spark testers)
Ive fitted a new coolant temp sensor, spark plugs, HT leads
Am i right to assume crank sensor is ok, if it wasnt i wouldnt get spark or fuel?
All earths are in place and ive checked all wiring also paperclip test shows no codes, ive tried another ECU
Only problem i see is while cranking the EML stays on
If anyone can shed some light on this please.
1 - 1 of 1 Posts
