Its been almost a year since i did my conversion. As far as i remember it was simply the case of unplugging my "coil adapter" which is a short custom wired harness, and pluggin the end of the MBE loom straight into the diss-pack. But the diss-pack has a 4 pin junior timer style plug, then end of the MBE loom with the yellow band marked "coil" has a 3 pin junior timer connector.
Now, did i fit this 3 pin junior timer to the main MBE loom myself so that my coil adapter harness fitted, i cant remember. I have a 4 pin junior timer blank in the leftover bits. This theory kinda fits, but the 4 coil wiring diagrams that SBD gave me make no sense. theres 4 piccies, bosch coil, corsa coil/amplifier, ford dizzyless, sagem-valeo-siemens coil.
