Been enjoying really great improvement in the idling behaviour on the C20XE, but any engine using this type of ICV should benefit from this readjustment.
With the stock adjustment it starts with a small opening, then closes first, then opens up again, and in this area it can fully open. The small opening is said to provide air in case of a wiring/ICV fault, so it still runs.
The change is to readjust it so this emergency opening remains at the other end of the valve, so in case of a fault in the wiring/ICV it still runs, but the trick is in the valve never fully closing at all, which is, according to a few (including a Vauxhall technician involved in the discussion here) totally unnecessary, even unwanted.
Most these engines now and then have the tendency, when the throttle is released fully (when shifting, when stopping, manouvring etc.) to go too low in revs, sometimes almost stalling, then the ECU detects and corrects, revs first go up in a burst and then stabilise.
With this mod this effect is completely gone. The revs may go down a tiny bit slower, but very acceptable, and once down they tend to be more stable too. Plus the whole transistion towards idling goes very very smooth.
Mind you, the grub screw in the side of the ICV is very well bonded with epoxy, and needs to be very well heated with a good gas flame. Also beware not to heat up the whole ICV, as there are plastic parts inside too. Apply the gas flame directly to the centre of the grub screw, and every now and then scrape excess epoxy away with a watchmakers screwdriver. Use a nicely small one that can also empty the allen key hole, right up until the allen key fits in nicely. Then adjust with the engine running with the ICV unplugged, until the revs are about 900, to keep a little adjustment range for the ECU. Then apply some nailpolish to lock it again and plug it on.
While you are at it you might want to relocate the ICV as well. I've drilled and tapped a hole in the back of the throttle body, under the butterfly, at the back. Then bolted in a 90 degree knee with some thread bond. And off course I put a plug in to the hole where it used to be, and ordered a custom hose from Roose to plumb it back on the SFI box. Obviously the TB work needs to be done off the engine, so remove it first!
Enjoy a smooooooth idle for once!:thumb:
