I've only tried to have a quick look but with oil splashing onto other parts its hard to find the leak properly without wiping it all down, before i do this and get seriously sh*tted up and unable to post on here mid job, are there any common places on a LET for leaks? the heavier oil residue is on the oil return pipe from the turbo, it has an oil pressure gauge fitted, could the sender/adaptor be leaking?
Ta :beer:
Sump,turbo return pipe,turbo return union,cam cover,cam seals,crank seals. Its impossible to say. As above,clean it then run it.
