Are the pipes that go into the oil cooler bendable or will they
crack? Anyone know?
Should be ok with a bit of heat just for a smallish adjustment.
I've got an 8-9mm ish pipe bending thing here if you want. May work if it fits.
Off to look at this car.
One of them old spring type things you slide in the pipe to stop it colapsing when you bend it.
