Got a missfire that happens only when it rains or i wash the car. It's got louvres in the bonnet which might be allowin water on2 the air filter and ignition coil and some of the loom, which might b causing the problem.
I check the ht leads, dizzy cap, coil, etc and there doesn't seem to be any moisture on anything electrical.
Does anyone have any ideas of what might b causing this?
Would a fault on the knock sensor or ignition advance (in the dizzy) cause it?
