1 - 16 of 16 Posts
Urgently wanted as mine has a leak. It's the one on the cambelt side of the fuel rail...
Wich Bit??
I need the rubber hose with the brass connector on the end. ie the fuel line that fits into the fuel rail.
**** me, has it started to leak?
Get a new union from homebase!
I thought the threaded section came out - like when the guy welded it? get a pair of grips on it chap, then it's a £1.50 repair!
Discussion Starter · #8 ·
Oh yeah it must do! :doh:
I'll get onto it today Dan!
Go to a pirtek,or hydraulic hose place,they can make you a new one,with your old fuel rail connector,then it just fits over your solid fuel pipe (that goes under the car)and a jubilee clip to secure,mine cost me £5.
Discussion Starter · #10 ·
Cheers Lee I will have a nosey! :beer:
Or got some fuel hose from a motorfactors, chop out the leaking bit (asuming its far enough away from the brass end) then join that on in place of the bit with a hole in?
Discussion Starter · #12 ·
I've got a feeling it's the brass connector that Al snapped that is leaking :eek:
Ah.... well if Al was involved id just go to vaux and order a recon engine with all auxurillies and pipe work, should fix it :p
Discussion Starter · #14 ·
Yeah, I'm still finding bits of Doritos even now! :(
1 - 16 of 16 Posts
