1 - 7 of 7 Posts
the 2 white ones are to heat it when you 1st start the car and its cold. one of the others is a 12volt ignition feed and the other remaining wire should fluctuate between 0.1 and 1 volt providing the lambda sensor is working.
1 - 7 of 7 Posts
