When the car is stationary with the engine stopped or running I get a knocking when the steering is turned slightly from side to side (as you would do to check for play in the track rod ends).
This knocking is not noticable when driving but there is something not quite right with the steering, especially when pushing it a bit. The car's a MK3 2.0 Sport with 70k on the clock.
The following can be eliminated as they've recently been renewed and i've checked they are torqued up correctly:
Front Shocks
Lower Wishbones
Anti-roll bar drop links
All Engine Mounts
Strut Brace
There seems to be absolutely no play in the steering by the way. Track Rod Ends seem to be solid. Wheel bearings don't have any play in them. Steers from lock to lock smoothly. Tracking was done ~1k ago and no kerbs or big holes have been driven over.
With someone else turning the steering i've noticed the following:
1) The rack moves very slightly sideways in it's mountings (~2mm) the mounting brackets are tight and don't move
2) Tops of front shocks move very slightly (with the play in the rubber) in the top mounts (~1mm)
Are the above normal? and has anyone any idea where else the knocking could be coming from?
Cheers :beer:
Ben
Front Shocks
Lower Wishbones
All Engine Mounts
Strut Brace
Cheers :beer:
Ben
