Status
Not open for further replies.
1 - 8 of 8 Posts
as above a pair of fast road cams for a redtop c20xe engine
Make:Kent Cams
Model : AST1612 (Fast Road)
Power band: 1500 - 6500rpm
Lift: 10.08mm
Duration: 260 degree
Full lift: 110 degree
Gains : +7bhp - +17bhp
they should work with both dizzy and coil pack engines as it had the hole for the cam sensor leg but were used in a dizzy engine
also comes with dizzy as the rod is shorter due to kent cam inserting a ball bearing
includes 2 new cam oil seals
Price is £175 + free postage (next day recorded delivery )
replied mate
coil and dizzy use the same block and heads and rocker covers where the dizzy sits you have a cam sensor ill jump out and check if its got the extra hole for the cam sensor lug to bolt on
(provisionally sold at the moment in time anyways)
yeah it looks like it has the second hole for the cam sensor leg to bolt on to it
Discussion Starter · #8 ·
Sold to a2 :)
1 - 8 of 8 Posts
Status
