is 316 stainless steel good for a manifold running gt3071/76r
1.3K views 22 replies 6 participants last post by  TheWelsh1
It won't last forever if you're gonna be making it glow regularly - man up and get some 625 :D
321 would be a better option iirc, it's better at high temp than 316. That said, 316 will probably be fine, if not long term. My reference says +850deg continuous use and it won't be stainless any more. That sort of temp is glowing red for reference.
321H will be better still as regards temp but will be more brittle.
Yeah that's why I mentioned glowing red - even if you don't know your EGTs or how much of that heat is transferring into the steel, if it's glowing then it's hot enough to matter. Ceramic coating would be good, but then the expense might put you in a position where you could have used something better, for less.
If you do get it somewhere towards 900deg, the chromium (that makes austenitics resistant to corrosion) will form compounds with carbon and it'll start corroding the whole thing, rather than the chromium forming a protective oxide.
Anyhoo, since most exhausts are probably made out of this, I wouldn't worry too much. Use what you can afford, just don't expect it to last for years.
but it looks so purdy
I was joking. I couldn't give two ****s what it looks like providing it works :)
