Hi guys,
I am planing to install c20let engine and f28 gbx in to Opel Kadett D (astra mk1 in UK), so I need all info I can get. I allready have long half-shaft from gsi, inner cv joint and flange from f20 gearbox. I've find the dimensions for the bush but I can't find from what material it is made of.
And I have question about engine mounts...from what car I can use metal part of them and from what car I can use rubber part? What needs to be done to fit it?
I plan to use programable engine management so wire loom is not a problem,
Any other advice welcome :)
P.S. My Opel has 1.3 for std. engine...
sorry for the bad english...I'm from Croatia...
regards,
Tonci
you need to just get the front legs from as 1.6 or 1.8 mk1 or mk2 astra/kadett then put these on. you will also need the fuel tank and pipework for the injection system. apart from that it will go straight in
