Here is my Innovate wideband Kit for sale.
This is complete and comes with everything that it came with when new (except for the lambda boss and bung) instructions and cd included (not in pic)
This has been used for no more than an hour or two.
Perfect workig order and in pretty much "as new" condition.
I've fitted Amp Seal connectors to the Lc1 and to the gauge.
Only selling as I am upgrading to an Innovate LM-2
Also I've spent some time making a wiring loom up so that you can simply plug this into your cigarette lighter socket and away you go (can easily cut off the plug and wire straight into your car making this much easier to fit).
Cost me over £200 new not including P&P and the amp seal connectors and the loom.
Looking for £175 delivered to your door ready to plug n play!
Someone Muat need one of these? By it now before you run lean and melt your engine :)
£160 delivered no offers :)
Gauge is very thin (aprox 1cm thick) so can easily be mounted anywhere with no need to cut out a big hole or use one of those anoying gauge pods
