Title
INJECTOR CLEANING / TESTING
DescriptionOk well ive been thinking for a while i need to offer this service on here as im guessing it is something people would be intrested in or need at some point in time
ok so this is what i can offer here at my work i have a ASNU injector testing and ultrasonic cleaning machine and im offering to migweb users a discount on this service i provide
i will be charging £11 per injector for the following(as per ASNU specification);
other companies are currently charging £11.50 + VAT per injector for the same service
all injectors will be sent back via royal mail recorded at a cost of £5
I will at current only offer this service on:
any injectors you send to me i ask that you mark 1-2-3-4 so i know which cylinder these came from and to help with diagnostic purposes(if it is possible to do so), any injectors that remain faulty after ultrasonic cleaning and diagnostic i will seal in a separate bag from the others and clearly mark
this is the machine we use to test and ultrasonically clean the injectors
if anyone has any questions about this service please feel free to contact me via my work email or PM me thought migweb
a order form is attached to this post but please make sure you contact me before sending any items out
Email: [email protected]
COSTS
£11 per injector
£5 return Postage this is for upto 6 injectors so to include the V6
Declarationok so this is what i can offer here at my work i have a ASNU injector testing and ultrasonic cleaning machine and im offering to migweb users a discount on this service i provide
- Micro filter, O ring seals and pintle caps are removed if able to be replaced / renewed.
- Check that all the injectors share the same part number.
- Injectors mounted on the flow bench and a leak test performed.
- 30 seconds at up to 5 bar pressure with the injectors closed.
- Flow rate testing at either 2.5 or 3 bar pressure. 50% duty cycle for 30 seconds.
- Check spray patterns in a static (wide open) mode.
- Check spray patterns in dynamic (pulsed) mode at a set open duration and speed.
- Injectors are placed into the into the ultra-sonic cleaning tank for a minimum of
30 minutes. During this time the injectors are also electrically pulsed. - Leak, Flow test and Spray pattern checks are re performed.
- Filters, O rings and pintle caps that were removed are renewed if available / stocked.
- top feed injectors and
- side feed injectors
- Japanese(some Filter for these are hard to source so standard ones will be cleaned while on the injector)
- American(some Filter for these are hard to source so standard ones will be cleaned while on the injector)
COSTS
£11 per injector
- I the seller have read and understood the Classified forum rules and understand that buying and selling on MIGWeb is done at my own risk and that MIG Performance Vauxhalls can in no way be held responsible for issues arising from using this service.
