- I choosed to use GSXR 750 srad 98 ITB's :
- First mod was to align each TB with the C20XE head ports, and plug the bike injector holes as I use the stock C20XE intake injectors holes.
- Use of the standard inlet manifold.
- Stock C20XE injector rail. Use of the stock GSXR Throttle position sensor as I can calibrate the Megasquirt ECU for any TPS.
- Brake servo connection and home made carbon velocity stacks.
- Carbons stacks was not a good idea...
- Ashley 4-2-1 exhaust!!.
- ITG filters fabrication.
- Now much better!!.
