In my Astra mk3, I've got two un-housed switches which are currently just hanging around loose.
So what I've decided to do it put a plate over the top of the rubbish bin (near to the *** lighter) and insert the switches into that. All good so far. Until it comes to wiring it in. Where there is a small clear plastic "thingy" (presumably for a non-existent light?) in the bin in the corner, I've popped that out, and was going to run the wires into the bin to the switches thru that.
However, to get the cables there, there are no holes in the plastic behind, and no way to get it via the *** lighter unit, so the only solution I can see is to simply drill a hole through the behind-panel.
(Have I lost you?) I'm just wondering if anyone has any better solutions before I hack it to bits. If i can I'll get some picures up.
