gte gearbox fault
630 views 5 replies 4 participants last post by  Gaz86
#1 ·
hi i have a 16v gte with f20 box,but lately seems to be difficult to select gears when driven for a while. also get a loud whining noise when pushing clutch pedal which i think must be release bearing. dont know a lot about gearboxes so does any body know what could problem be? it also crunches into reverse,tried tightening clutch cable but still does it! could this be because gearbox oil low or somthing to do with clutch
#3 ·
pretty old but doesnt slip and bites straight away! would clutch cause difficulty engaging gears if it still bites at bottom? its fine cold just after a good run starts getting bit sticky in gears when hot.
#5 ·
bought the special oil from vauxhall but looks difficult to tip from bottle into the little hole without spilling.also manual says about a plug near driveshaft you have to take out to check oil level,but i cant bloody find it!!! could linkage cause problems and make it grind every time you put into reverse? also the pin and u joints seem bit baggy above box but aint sure how much play there supposed to have!
