funny odd, not funny ha-ha.
my mum's corsa is showing some strange lock behaviour. it's new (to her) so i don't know the history of them.
the driver side is very sloppy when it's being locked, there is no real distinction between the part lock (meant to have resistance at 45 degrees) and the full deadlock position.
the boot lock is quite whacky, and it feels like an electric motor is being turned when you lock it.
obviously the boot is something to do with the central locking, do you reckon the two things are related... and could it be an electrical fault with the central locking? (cl works ok)
door lock is just worn my cav did the same thing no fix apart from buying a new assembly possibly. boot lock sounds like the c/l motor isnt working id say its either broken and been unplugged or its just broken take the plastic boot trim panel off and seee if its plugged in. its probley broke so just a case of poppin a new one in easy 5 minute job
hope this helps
