1 - 7 of 7 Posts
Calibra C20XE Redtop motor.
Broke down the other day.Recovery arrived and told me the fuel pump was gone.So i replaced it.Car started but only ran for about 5min.Checked the pressure in the rail,ok.
Then i replaced the fuel filter.Now i have pressure in the rail but no fuel.What have i missed,anyone?
Have you put the filter on the wrong way? there is an arrow that points - should point in the direction of the petrol flow- arrow away from the pump
the relay powers up the injectors, part of the ecu, the fuel pump, idle control valve, and fuel tank vent valve.
so it may be linked, like ross said.
yep i got what you're saying but if the pump is working surely the rest should be working.
1 - 7 of 7 Posts
