2 connections for fuel, one on the drivers side, one on the passengers, what one goes to the same plate the fuelk sender is on, on the tank ?
arnt both of the pipes running dwn the same side? i always thought that there were two pipes toghether and the abs on the passenger side
the 2 pipes that run to the fuel tank, both go in to the engine bay then then a rubber pipe up to the engine (fuel rail?) just wanna know what one is which
Probably is, but I can't say for sure, not had a close look at the hose layout on the tank under a Cav GSi. Easiest way to find out is follow the feed back to the pump under the back end of the car and then follow the hose from the pump to the tank and see where it ends up ;)
