just received a full set of gauges, boost, oil temp. oil pressure, water temp and voltage.
i'm pretty sure i can handle the water temp and voltage gauges but i'm unsure of the others
the cars a vectra but the engine is a c20let, does it have the oil temp and pressure senders already? as this would make it slightly easier, i'm guessing it does but where bouts is the plug? is that one that comes out of the sump? dont supposse anyone knows what colours are which?
The one out the fron of the sump is oil level indicator. There is a sender at the back of the engine for pressure and low pressure warning,i think you may have to either t-off or use another outlet for your after market guage. Do a search it been covered,pics and explanation too.
Boost is simple,pipe into any vac line after the throttle body,the one going to the ecu is my first choice.
