Currently converting my manual sunroof in my astra to an electric one. Got all the parts needed, and was halfway through fitting it when i discovered the existing loom has four wires going into a block connector, which plugs into the interior light. The conversion instructions i have say i can split the 'live' wire to supply the sunroof motor as well as the interior light. The problem i have is that i can not identify the 'live' and 'earth' wire from the four. The original alarm sensor is there, so i'm guessing the other two wires must connect to that?
Any help would be appreciated, as well as anyone who knows which wire is which.
My girlfriend's Corsa B has been converted to an electric sunroof from a cavalier but it is powered straight to the battery via a wire with a fuse on it (Aftermarket) i have not personally had it off though to see how it is wired up.
Thanks Mark, bookmarked that!
I assume it would be the same procedure for putting a one-touch in my Nova?
