1 - 1 of 1 Posts
Hello guys
this is my first remap i hope to be on the right side
Smile
I own an opel meriva A, 1.3 cdti enjoy, 75hp 55kw year 2007
I was able to read ECU ( attached files easyupload.io ) by Ksuite tool and the kessv2
that I bought to try to improve the performance of my car
considering poor recovery and acceleration,fuel consumption, less power while using A/C
My goal is:
more power and torque, reduced fuel consumption, smoother acceleration and improved throttle response
Also, I have the problem of the instrument cluster to be replaced (broken display)
but despite having another one with the same code, once plugged, the car does not start.
So I wonder if in the file just read, there is the possibility to remove this code so that I can replace it without problems instead of using the op-com or op-tech?
can you help me?
Thank you !
1 - 1 of 1 Posts
