Whats the best way of filling bumpers i bought some flexable filler stuff from halfords fibreglassed a bit of plastic behind the holes and fillered over the top and its cracked out
BTW i'm trying to fill the holes for headlight washers on an astra gte
Chris
plently of strength on the back to redce flex and key the surface pretty deep, keep filler content to the bare minimum use as much plastic as you can - and alredite isn't bad to stick stuff down but doesn't like filler so keep it clean
filling bumper's
just put a bit of cardboard on the other side of the holes on the inside and fill over the cardboard to keep the cardboard in place then fill on the top, then the filler should go over the holes and build up and then it will all go through the holes and stop at the cardboard and it will stop the filler sinking and falling threw.
mike.
