Boost gauge fitted came up with some interesting problems...listen to these
1st gear holding 15psi upto 3500-4000rpm..and then drops to 11psi
2nd gear similar situation but about 12psi after 4000rpm
3rd gear and the car is running 14psi max boost.
4th gear running 15 psi no problems.
5th gear 15-16psi
6th gear foot to the floor above 3000rpm 16 psi constant.
What do you reckon actuator [email protected]!ked?????
just thought I would let you know.
Also had a brain storm today and spent £600 on a intercooler (as recommended by the guy at Wallace) he reckons the 8.1 litre intercooler will benefit to no end!!!
5th gear 15-16psi
