Originally posted by robert:
<STRONG>Also using super unleaded which seems to help quite abit.
</STRONG>
Please dont tell us you were using normal unleaded when you were running a superchip and boost at 15psi
The octane rating is not going to be high enough so detonation is going to occur in the engine. The ECU will pick this up and retard the timing so as to prevent this detonation which drops power a LOT.
Run the tank with Super Unleaded and fit the intercooler. Once you have done that, reset the ECU overnight (minimum 1 hour) and then re-connect and drive the car. This will reset the ECU and it will learn to drive with the Super Unleaded petrol and not retard the ignition so much. It will also learn about the intercooler (colder charge) as well.
I will gaurantee an increase in performance by a noticeable amount when you do this.
Keep the boost at 14-16psi even with the intercooler. The superchip is good enough but its not mapped specifically to your engine (like a UniChip) so the fuelling etc wont be precise enough to run any higher without fear of running lean (which all superchips s'posedly do at the top of the rev range). You do NOT want a turbo engine to run lean
You may want to consider fitting a Weber Fuel Pressure Regulator (or Carls Motorsport 4.5bar one..... same ppl that do the intercooler and available from Gavin Wallace again) to nake sure the fuelling is better.
Oh, and for gods sake
NEVER RUN NORMAL UNLEADED IN YOUR CAR unless you have to (like when you are nearly empty and need petrol) and only then put just enough to get you to the next garage with super !!!
Rich
[ 17-07-2001: Message edited by: Richie ]
