1 - 10 of 10 Posts
Been looking for a short shift kit for the F28, firstly its in a Mk2 astra so would it of been modified to fit? and will this cause any problems with a short shift kit designed for the calibra/cav? if not where and how much?
Ta again
I got an F28 quickshift from LMF for my Mk 3 Cav, I`m sure it could be modded to work on the Mk2 astra
I'm interested in this too as I got a B&M short shift gearstick but was also wanting to source a quick shift linkage.
Joy - where did you get the LMF linkage from?
Cheers, Ian.
GlennJ said:
Short stick would be cool also... where can you get the B&M one from?
I got mine from Demon Tweeks IIRC, cost more than the linkage though at £150+ but you get a nice solid aluminium gear stick :cool:
I wonder if anyone has fitted both the gear stick AND linkage together?
Discussion Starter #9
thought it was all part of the kit? i think the linkage is not actually the linkage between stick and box but is a modified linkage between the stick and linkage, not sure though. Has your b+m stick made any difference to the throw or is it just cosmetic?
1 - 10 of 10 Posts
