Hallo!
So Ive started My new engine with new clutch and everything, starts up good, but the clutch wont engage. It’s either clutch cable that is tightened too much or the friction plate is in reversd, but is it possible to even install it backwards? Hope anyone Can help. (Lightened flywheel and SPEC stage 3+ clutch btw)
i Can set the gearbox in gear,but nothing happens when i release the clutch pedal.
some clutch plates only go in one way, but some can be put in backwards, if your not careful.
check everything is ok with the pedal, cable, arm, and fork, first ... before you take the gearbox off again.
what brand of clutch did you fit, by the way ? ... as cheap ones are made of crap materials, and sometimes wont engage.
