1 - 11 of 11 Posts
the light on the dash for the engine coolant has come on today. its full upto the mark on the bottle and the fan comes in but the light stays on. any ideas?
S reg 98 CDX 1.8
Admin/show reporter
broken wire, the expansion tank will have a sensor on it, there will be a few wires coming out of it. Check these are ok.
Yep. Could be the cap, or the wiring to it. I'm sure there would be someway to test it, but I don't know it. Try a friend with the same control lights, doesn't have to be the same car. Just wire the cap in, and slide the plunger up and down and see if the light goes out.
there is NO sensor on the coolant tank. the wire is there but no sensor. and no wires on the cap. is this normal ?
Is there a sensor lower down the bottle. Should be a float type sensor. Not sure if these are used on the later ones, but would imagine so.
Tech2 is the Vauxhall computer to diagnose faults on later Vx's
Discussion Starter #11
no sensor at all, had the bottle off the car. so i need to take it into the dealers then ? thats gonna be expensive i bet
1 - 11 of 11 Posts
