Right i ot the corsa back on the road yesterday with the LET in it and it goes like mad! one of the niggly probs ive got now though is the speedo is reading miles out. when im going about 40 it is showing about 20. im using the F28 with mechanical speedo drive, does this always happen on these transplants? whan can i do about it?
Not sure if this could be related but when i lowered the old engine out i forgot to disconnect the speedo cable and it pulled it apart (the join just before the bulkhead came unclipped) but i clipped it back together and it seemed fine
Unless you are using the 160mph clocks you'll need to change the speedo ring to one out of an f20. This requires the box to be taken out and split. The f20 ring is about £10 new from the dealers.
Saying that it would be much easier to find the 160mph clock imolmao
Thanks for clearin that up mate, the gearbox is stayin where it is now its all finally in! the 160mph clocks are out of a calibra yeah? does it take much to fit them?
