Don't know if you can help me or give me any idea what the problem could be, I was changing a coil pack put the cable back in but it wasn't in properly, started the car all was fine then i accidentally knocked the cable and the car stop running and won't start but all the dashboard lights come on, I have noticed that the ABS light is flickering but now i have check the battery and the fuses, i have been told it could be power/earth wire issue and now I have taken off the ecu to get the information from the ecu then i put it back on the car and now when i turn the ignition on and now there's no lights coming on and central locking is not working,
